I've to say again: sorry for my english.
:womansad:I've found the answer to my problems in the NI-VISA user manual.
"Accessing Multiple Address Spaces
You can use LLA operations to access only the address space currently
mapped. To access a different address space, you need to perform a
remapping, which involves calling viUnmapAddress() and
viMapAddress(). Therefore, LLA programming becomes more
complex, without much of a performance increase, for accessing several
address spaces concurrently. In these cases, the HLA operations are
superior.
In addition,
if you have several sessions to the same or different devices all
performing register I/O, they must compete for the finite number of
windows available. When using LLA operations, you must allocate the
windows and always ensure that the program does not ask for more
windows than are available. The HLA operations avoid this problem by
restoring the window to the previous setting when they are done. Even if all
windows are currently in use by LLA operations, you can still use HLA
functions because they will save the state of the window, remap, access, and
then restore the window. As a result, you can have an unlimited number of
HLA windows."
But how many windows are available?
Thanks very much fot your patience!
Message Edited by Alessio Zanetti on 07-18-2006 10:08 AM
