difference between event structure and case structure
Hi, can anyone tell me the diference between an even structure and a case structure with an example.
Regards
RobinHood
(8,026 Views)
(8,021 Views)
No Mike.I didn't.
Regards
RobinHood
(8,011 Views)
They didn't specifically mention any differences. can you just make out any differences with one example.
Your help is well appreciated
Regards
RobinHood
(8,010 Views)
There are many differences between a case structure and an event structure.
In simple words,
An event structure is used to handle user events. For example click of a button, closing a pane, value change of a tree. (Which just needs an addition of a event case in the event structure, whereas you might have to code a bit more with different architecture using a case structure)
A case structure is used handle conditioned states like TRUE/False, number within range or no, error/No error. (Which are not possible to perform with an event structure.)
I guess the links mentioned by other posters here is quite good enough to get started with these structures.
Message Edited by Vsh on 03-08-2010 04:25 AM
(8,004 Views)
Besides using the help that comes with LabVIEW, you might want to look at the menus and then go to Help>Find Examples.
(7,975 Views)
