determine number of monitors
How can I determine the number of monitors in Labview. In Labwindows you have ATTR_NUM_MONITORS but I do not find the equivalent command in Labview.
(3,660 Views)
Accepted by topic author lucchris
Drop a property node. It will already have the Application class selected by default. Select the Display>>All Monitors property, which is an array with the details of all the monitors. You can look at its size for the number.
___________________
Try to take over the world!
(3,652 Views)
