detect port serial automatically
I can't make my VI detect the connection of a serial port automatically, I don't want the user selecting the port COM*?
(5,403 Views)
What have you tried? With either VISA Find Resources or the System tools you can get a list of all com ports. After that, you send a query to each one until the specific instrument is detected.
(5,387 Views)
Use the VISA Find Resource to find the resources and then use a FOR loop to filter just the ones you want (COM ports).  You can then use a FOR loop to check each serial port to see if it is the right one.  For connecting to a streaming instrument, just do a read and see if it matches the expected data format.  If it is a command-response instrument, you just send a command and check the response.
(5,380 Views)
Accepted by topic author Andrespp
If you're trying to find USB com ports, maby one of these will help.
(5,212 Views)
Thnx! it works. It is what I was looking for.
(5,093 Views)
Hi paul
could you pleas put these files with lower version .
(5,046 Views)
Here's LV 13.
Also, this time I didn't forget to include the subVIs for 'Find Specific Com Port.vi'.
(4,973 Views)
