detailed help not active
I  try to use "show contex help" from Help. I can not make "detailed Help" in "context help" window active, that is, when I click "detailed help", there is nothing happening.
I even reinstall labview 8.6, it is still like that.
Please advice how to resolve this problem?
Liming
(2,925 Views)
Are you trying to do this from within an application? Is this when the Context Help is over a LabVIEW function, or one of your VIs?
(2,912 Views)
Are you using Windows or a Mac OS?
Also, does the cursor not change or allow you to click the detailed help, or can you click it, but no window appears?
Chris Van Horn
(2,887 Views)
I use windows Xp.
I can click it, but no no window appears.
(2,869 Views)
You might want to try this link: http://www.drexplain.com/press/chm-files-the-page-cannot-be-displayed-error/
It would be the fix if your computer is blocking the chm file that the detailed help is loaded on. It seems like your computer is blocking the help one way or another, wheteher it be anti-virus or this problem.
Chris Van Horn
(2,865 Views)
