destroy window error
Does anyone know what this error message means? I'm getting it in a place that worked fine till now and I didn't change anything in the code...
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
(3,250 Views)
Could you post a screenshot of your error please.
Mathan
(3,245 Views)
I attached the screenshot of the error. Any help would be greatly appreciated.
Danielle
― Terry Pratchett
(3,237 Views)
Hi Danielle,
when do you get this error? What do you make in your program? Can you give more details, please?
Mike
(3,231 Views)
In my program I acquire data from a Data Translation (DT) card. In this section of code I control voltage output, and then I read voltage input. It worked well until now. Today, when reading the voltage input, I recieve the error after using the "get value" function (built-in DT vi). When stepping through the "get value" function, everything is fine until I exit the vi and then the error occurs.
I tried running a different section of code that also uses the "get value" function to read voltage from the card - it works fine.
Does anyone have any idea what could be wrong?
Danielle
― Terry Pratchett
(3,220 Views)
