09-18-2008 11:26 AM
I am trying to evaluate an SBc for RT suitability which on paper it should be but when I use a USB drive to boot the utilities none of them work. For example the start menu appears bu selecting any option causes no response apart from reset the system or advanced ethernet settings.
Is this case a case of incompatibility before its started evaluating?
09-22-2008
11:54 AM
- last edited on
09-04-2025
01:24 PM
by
Content Cleaner
Hi Peter,
Please can you look at this KB it describes the system components you need for real-time to run, but also discusses possible reasons why the utilities do not work. Your HDD has to be formatted as FAT32 for the programs to run and work on your system.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
