designing utiliy for configuring the devices??
I want to make my own utility for configuring the daq devices like measurement and automation explorer.
I want to design the user interface on labview and dont want to use DAQ Assistant and MAX.
I am not able to search which device are connected to my pc.presently I am working on NIUSB-6009
Is there any VI or Prorperty node which can give the information of connected devices like maxor Daq Assistant???
VG
(2,586 Views)
Hello Vivek,
try the "system node" and the "device node" as starting point. In LV 8.5 you find them under Measurement I/O --> NI-DAQmx -> Advanced --> I/O Constants. The attached picture shows both nodes in action. But I think you get the DAQmx devices only.
HTH
Uli
(2,570 Views)
Thanks for your Support.
It solved my purpose.
Best regards
Vivek
(2,561 Views)
