derivative function
My program has a derivative calculation. I want to calculate the 2nd derivative of my X,Y-dates. My XY-dates describe a curve, like the graphic in the attachement!
But i am not sure about the assignement from the ports! Is the assignement from the ports right??
PETER
Message Edited by Steirer on 07-29-2005 09:05 AM
Message Edited by Steirer on 07-29-2005 09:06 AM
Labview 7.1 on Windows 2000
(3,795 Views)
Hello Peter,
to get the 2nd derivative you have to call the "Derivative.vi" two times. The parameter you wired with "2" is the sampling period (kind of accuracy). Have a look at the help window!
Perhaps you can include some example values in your X/Y-array as default values?
Message Edited by GerdW on 07-29-2005 09:46 AM
(3,780 Views)
HI!
I tried to type in some example values, but when i start the program, each array-element has the same value. Because of that, i wall write in this topic some example values!
There is an example: X - Array (10, 19,32,45,51,67,76,81,99)
                                   Y- Array ( 0,2 / 0,191 / 0,17 / 0,16 / 0,13 / 0,16 / 0,18 / 0,19 / 0,199)
The example values should descrive a curve, like the picture above (in my first post )!
I tried to run the program, but the result is only "inf" or "NaN".
What is wrong???
Peter
Message Edited by Steirer on 07-29-2005 10:20 AM
(3,777 Views)
Hello Peter,
when I use your values I get no inf nor NaN...
See attached example (I only scaled y-values by 1000 for easier typing 🙂
(3,767 Views)
HI GerdW!
Thank you for your help!
PETER
(3,764 Views)
