derivative dt term
Since I'm not running in realtime, my loop rate might change.  What is the best way to make sure that the derivative block is always supplied with the correct dt term (one that reflects the actual time between the two "measurements")?  I tried measuring loop time and supplying that into the block input, but it doesn't work.  Any ideas?
Maciek
(2,625 Views)
I have posted an answer to this question to this thread.
Jochen
(2,601 Views)
