delphi labview interface
I would like to pass a few data values from a Labview application to a Delphi application running on another computer on the same local network. Does anyone know if it is possible to get Delphi to read Labview's shared variables or is there another way to do it?
Thanks.
Rat_Lab.
(3,502 Views)
Hi Rat_Lab,
i think you have to know the format of the shared variable data to read the values in Delphi. I think the easiest way is to use TCP/IP to send data between your applications.
Mike
(3,494 Views)
Thanks for the reply Mike, I will go with the TCP/IP solution.
Rat_Lab.
(3,450 Views)
