deleting elements of one array by comparing it to the elements of another array
I m a newbie to LabVIEW and I have a very basic question.
I have two arrays. The first array contains a certain set of elements
For e.g.  1 2 3 4 5 6
The second array has another set of elements
For eg. 2 5 6
Now I want to delete the elements 2 5 6 from the first array and plot the first array with the deleted elements on a waveform graph.
Can anybody help me out?
Thanks and regards.
(3,391 Views)
you could do something like this:
Greets, Dave
Message Edited by daveTW on 02-23-2007 05:07 PM
Greets, Dave
(3,383 Views)
Prakruthi,
attached you can find a picture of a working solution, but it is definetly NOT the best one.
Disadvantages:
- Direct comparison with "=" should only be done with integers. Floating point number have some major issues here since 2.00 != 2.00 (not always, but more often than suspected!).
- Due to the two nested loops there could be some overhead which can be prevented with other approaches...
nevertheless, i hope this helps 🙂
Norbert B.
Norbert
Expert: Geometry
(3,377 Views)
Dave,
your solution looks nicer than mine, i have to admit. BUT: what if you have e.g. "5" in your array twice or more times??
Norbert
Norbert
Expert: Geometry
(3,374 Views)
Hi Norbert, you are right, this is not worth a star Smiley Sad
But I put in another while loop and it should work...
Greets, Dave
Message Edited by daveTW on 02-23-2007 05:26 PM
Greets, Dave
(3,370 Views)
Hi Dave,
Thank you for the quick reply. That is exactly what I tried to do. But Im doing something else wrong. My final waveform, still appears with the undeleted elements.
I have attached the vi for a better understanding.
Thanks and regards,
Prakruthi
(3,367 Views)
