delete matching elements in an array
I need to delete the matching elements in an array.
for example if my array looks like this
A    1
A    2
A    7
B    2
B    2
B    4
C    5
C    7
C    7
I need to be able to delete one of the matches.
Thank you
(4,037 Views)
OpenG has a Filter 1D array function, which accepts a scalar or an array of elements to remove.
(4,030 Views)
I dont have OpenG downloaded, i was wanting to find  a way without it
(4,027 Views)
What have you tried?
A FOR loop with a shift register containing the found values and a Search 1D Array should get you at least half way there.
(4,005 Views)
Is there a reason you want to re-invent the wheel?  You may have a legitamate reason for not wanting to use OpenG which is why I'm asking.
But in my opinion no LabVIEW developer should be without OpenG.  Even if you don't want to use OpenG you can open the source and see how it can be done.
(3,988 Views)
