delete ending zero of a string
I want to convert an array of floats, for exemple [12,123; 1; -46,2] to a string (with array to spreadsheet string vi) .
Actually, I have the string : "12,123000      1,000000      -46,200000"
But i want to have : "12,123       1        -46,2", without the ending zeros, which are particulary useless, and take a big place when you save it to a file in txt.
Thanks for your help.
P.S : it's useless to propose to search the 0 after the ",", and delete them : this solution is verry horrible, and will take a lot of ressources with my big numbers of values.
V-F
(3,757 Views)
Accepted by topic author ramses64
Hi ramses,
read the context help for ArrayToSpreadsheetString, in the sentence for format string you click on "format string syntax" and then you see a table of all the formatting codes. This way you would have read about the "#" to remove trailing zeros...
So use a format string of "%#.6f" for your formatting...
(3,756 Views)
