delcom
I have a Delcom USB HID Hand Held Programable Button Switch, and I would like to use it in Labview. I would like Labview to tell me when the button has been pressed, but for some reason I cannot get the program to read the device. I downloaded the DLL from the website, and even when I try to run the program with the sample programs from this website http://www.delcomproducts.com/tech.asp. and I still cannot get it to work. Any help would be greatly appreciated.
Thanks!
Message 1 of 8
(3,942 Views)
If the vendor's software does not work, you need to contact the vendor. The only thing I saw on your link (an incorrect link) related to LabVIEW is a pdf file so I don't know which program you are running. It will be hard for anyone to debug something without your hardware.
Message 2 of 8
(3,937 Views)
Sorry, found the zip file.
Message 3 of 8
(3,936 Views)
Thanks!
If the vendor software isn't working, your first concern should be that you have a faulty product. Contact them.
Message 4 of 8
(3,925 Views)
This is the website that has the DLL
http://www.delcomproducts.com/productdetails.asp?ProductNum=890510
I've contacted the company, and the device is working, and shows up on the computer, but not on Labview, and I'm not sure why
Message 5 of 8
(3,922 Views)
Did you look at some of the other posts related to Delcom?
Message 6 of 8
(3,900 Views)
I did, and still nothing. The program will run, but none of the VIs in the DLL pick up the device.
Message 7 of 8
(3,894 Views)
Did you make any of the changes that the other users did? It seems the mentioned example was poorly written.
Message 8 of 8
(3,892 Views)
