delay time microseconds precision
I need good precision for time delay in the order of the fews microseconds. it is possible with a board 6023E .if yes  which is the bether solution.
Message 1 of 11
(7,871 Views)
I need good precision because my objectiv is make time resolved photoluminescense studies
Message 2 of 11
(7,867 Views)
What exactly are you trying to delay? If you're trying to use a wait statement, the answer is you won't be able to do it with Windows. If you're using some sort of hardware, what is it and how do want to use it?
Message 3 of 11
(7,861 Views)
I use a 6023E . I want make time resolved photoluminescense and for this i have a pulsed laser with trigger and i need put a delay after laser pulsed and i only later  can begin to measure . This delay is smaller than 1ms
Message 4 of 11
(7,851 Views)
I'm not all that familar with the specs on the DAQ board but DAQmx does have a Trigger Delay property. You'll want to look at the DAQmx shipping examples for analog and digital triggering. For example, Acq&Graph Voltage-Int Clk-Analog Start w Hyst.vi uses a DAmx property to set the trigger hysteris. Right click on the property node and select Properties and you'll see Start>More>Delay.
You might want to post your question in the DAQ forum with a little more specific information such as exactly how much of a trigger delay you need.
Message 5 of 11
(7,843 Views)
I also need to create very precise time delays.  I am not using an NI A/D , but I am wondering how precise the "Time Delay" feature can function.  Is it dependant on the computer speed, or is there a lower threshold just in the Labview software?
Message 6 of 11
(7,433 Views)
Hi njprice2,
the "Time Delay" ExpressVI is based on the "Wait (ms)" function and so works with a ms resolution. This is what you get on a standard computer.
Anything less is not possible with "high precision" as Windows will always get in the way with several background task! To get highly precise timings you need to look at RT or (even better) FPGA solutions or use DAQ hardware for such tasks...
Message 7 of 11
(7,426 Views)
You will have to use hardware delays.  Set up the 6023E to export its start event to some output pin.  Connect this output pin to the trigger input pin of your measuring device.  Setup the measuring device to trigger off of this signal with a trigger delay set to whatever you need.  You will need to arm the measuring device (DAQmx Initiate function).  The measuring device will then be ready and waiting for its trigger.  When the laser is pulsed, a trigger will be sent to the measuring device.  The trigger delay will happen, then the measurement will be made.
- tbob
Inventor of the WORM Global
Message 8 of 11
(7,389 Views)
Speaking of time delays tbob, that part of the thread is 5 years old.  Good answer though!  Smiley Very Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 9 of 11
(7,385 Views)
Oooops, quoted the wrong one.  I meant to quote the post done in 2010.  I usually look at dates, but not this time.
- tbob
Message 10 of 11
(7,371 Views)
