delay sound
Hello
    I'm trying to play an alarm using a .wav file my problem is that the wav file is 100 milliseconds long so I have to wait 100 milliseconds before I activate it again or it will overlap. Is there a way to wait 100 ms before playing the sound again?
I attached my VI
thank you
(2,875 Views)
Not the way you are doing it. You should not be placing an event structure inside a case statement. You don't need an event structure at all. Why don't you just place a Wait (ms) function inside the loop? Why even have the case statement since the value is always true?
You might want to look at the resources available at How Can I Learn LabVIEW.
(2,871 Views)
