delay line
So, it looks like you using the Stanford Research Lock-In Amplifier. Hard to read exact model number, is it 530 or 580?
First you need to download suitable driver for LabVIEW from Instrument Driver Network.
For SR530 it is here: Stanford Research 510 530 Amplifier.
If your Model is not present, then you can try with similar model, there are several available, for example Stanford Research 830, many commands on similar devices are "unified" and compatible more or less.
Then you need to connect it to PC (LabVIEW+Visa should be installed, obviously), then your first goal is to get device successfully initialized — you should have a response without error.
Just open VI Tree from downloaded driver - you will see Initalization VI:
Then use suitable SubVIs to get required data from your device. At first message you wrote that you have also step motor, but on the diagram the only Lock-In Amplifier is connected to the PC. If so, then the task is not very complicated.
Message 11 of 31
(944 Views)
Is it forbidden to contact by e-mail or any other social media account? I'm new to the forum. I'm asking because I don't know.
Message 12 of 31
(917 Views)
It is unnecessary and doesn't happen (often).
Jim
Message 13 of 31
(913 Views)
Is there any chance you can help me if I give you my instagram address? We can contact faster from there.
Message 14 of 31
(903 Views)
I would like to recommend to continue here. By the way most of social networks including instagram are blocked by our company's policy, could be the same for other participants in industrial/research environment. This discussion also can be useful for other engineers with similar problems. For example, here was discussed a little bit for similar model: SR830 Lock-in-amplifier data acquisition and save.
Message 15 of 31
(892 Views)
You've already been given the advice on how to complete your task.
You'd be most of the way to completing it by now if you'd followed the advice given and worked through the tutorials
Message 16 of 31
(876 Views)
It seems "unlikely" (and certainly "unprofessional") for a Professor to require a student or trainee to "finish a LabVIEW Project in two weeks" when they should know that the trainee (i.e. you) have no experience with LabVIEW and would not be able to do this "on your own" in this time.  It would be like asking me to write a short story of 20 typewritten pages in Greek (with, of course, Greek letters).  I might be able to "hand something in", but there's no way I could have been the author ...
Still, if "turning in the Project" is the only criterion, then I recommend that you hire a LabVIEW Programmer right away to do this for you (or really start studying at top speed!).  The purpose of this Forum is to help LabVIEW users who "get stuck" or "find a problem" that might be a "bug" in the latest version -- not to "do my homework" (or "do my Job") "for me".
If you are in a University environment, you might also check out undergraduate or graduate students in Engineering (Mechanical, Electrical, or Computer) to see if you can get "Hands-on Help".  There is also a Forum here in the LabVIEW Community under "Special Interest Boards" (look on the left side of the main Window that lists all the Forums) called "LabVIEW Developers Seeking Employment".
Message 17 of 31
(846 Views)
I definitely agree with your opinion, but there is almost no labview programmer ın my country. I searched a lot, but I couldn't find anyone to do my homework. For this reason I wrote here.
Message 18 of 31
(812 Views)
No, I dont agree with you on this issue. If you are given an assignment on a program that you do not understand at all, you cannot do it in such a simple way.
Message 19 of 31
(811 Views)
How far have you got?
What stage is your program at now?
I would assume it has progressed since you last shared it.
EDIT: It appears you've not shared anything previously. So what have you attempted so far? What can you do in labview? Which tutorials have you completed so that we can assist
Message 20 of 31
(788 Views)
