delay in MPC response when using update MPC window
I already have the simulation ready and this moment I am doing the process of simulation in the simulation where I applied the MPC tool and I realize that CD update MPC window exists in the response a delay of 2 seconds, when I do it for the CD step forward MPC window the answer is correctly anticipating. I check in your default example to compare my programming, I visualize the same error. You can help me because many thanks in advance
image.pngimage.pngit is the same variable of the same plant taken with the different vi mentioned above.
(2,460 Views)
Hi  oland:
I dont get what are you trying to do. Can you attached your code?
(2,419 Views)
