define the result
hello all,
i just want to know how to create a result that will display due to certain state:
example is like
if the output equal to 1 = good
                              to 2 = better
                              to 3 = excellent
did anyone got the idea how i can make it?
thanks
zull azym
UTHM
MALAYSIA
Message 1 of 12
(3,996 Views)
Use a Ring Indicator for it.
Message 2 of 12
(3,987 Views)
hello,
how i can find the ring indicator?
did u have any picture of it?
thanks
Message 3 of 12
(3,982 Views)
The LabVIEW palettes have a search function. Just click the [search] button on the top right of the palette and type e.g. " text ring" 🙂
Message 4 of 12
(3,976 Views)
Here's an example (LabVIEW 8.0):
Message 5 of 12
(3,974 Views)
thanks.
now i manage to know how to use the ring function.
thanks so much
regards,
zull azym
Message 6 of 12
(3,964 Views)
hello,
regarding to ring function, i have learn it and test it,
did i can use ring function to define certain range of data analysis,
let say;
range 0-2: good
          3-4: very good
          5-6: bad
thanks
zull azym
Message 7 of 12
(3,882 Views)
Hi zull,
it's not nice to ask the same in several threads! More information is found here...
Attached you find a way to select a string according to your "range" number using a case structure.
Btw. what you taling about is a "ring indicator" - it's not a ring function!
Message 8 of 12
(3,866 Views)
Nothing prevents you from having mutiple items in your ring.
(Of course this only makes sense if you use it as indicator only. As a control it would just cause confusion :))
In a more general case, mapping ranges to indices is most easily achieved using an array of boundary values and "threshold array". See the following thread for an implementation:
Message Edited by altenbach on 04-13-2008 12:03 PM
Message 9 of 12
(3,860 Views)
hello and thanks for the reply.
i'am so sorry about ring function which supposely
is ring indicator. about the values, how i can
have a range of two decimal point:i tried to put
it decimal point but it wont work.
let say:   0.0-1.9 (good)
               2.0-3.9 (very good)
so if the input is 2.3, so it would scale as very good.
regards,
zull azym
UTHM researcher,
MALAYSIA
Message 10 of 12
(3,845 Views)
