decimal seperator question
Hi all,
My problem is quite simple : I want Labview to ignore the localized decimal seperator settings and always use a period (I'm in Canada so most of the computers use a comma instead). I did set the option in the Front panel item of the Options menu and it works fine... in the VI. When I build an application with this VI and I execute it, guess what, the numeric controls on the front panel use a comma.
Am I missing something? Anyone knows how to fix it?
Alex
(2,579 Views)
hi there
all settings from the options are saved in the file LabView.ini in the LabView folder. the setting for the decimal seperator is
useLocaleDecimalPt=False
just play around with the options and see how LabView.ini changes.
When you create an executable the instance of the Runtime Engine (RTE) reads the file <your apps name>.ini in the folder of the application instead of LabView.ini, so you can adjust the options for each application as you like it. but be careful: the application builder may create a default (i.e. empty) ini - file that replaces an existing one, so always make backups. when creating an installer add the .ini - file to the list of additional files and install it in the applications directory.
another tip: for a "static" selection of the seperator i would prefer the "Scan from String" and "Format into String" functions cuz then i can set the seperator (and format and many more) in my code and not in a seperate file which may be edited or deleted. just doubleclick on the functions for more information.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,573 Views)
