dc voltage control using GPIB
Hi ....
                Can any one help me out in designing a VI which is used to control the external dc voltage source( max voltage 60v ).
Thanks and regards,
Sampath kumar chennuri.
(2,867 Views)
You left out the most important part if you want any detailed help. Namely, what is the make and model for your power supply. You can go to http://sine.ni.com/idnetwork/ and search for a driver for the instrument. You should also have a programming manual for it. With the manual, you can write your own program with VISA Writes and Reads or use the Instrument I/O Assistant.
(2,863 Views)
