date/time string function : indication of after or before
Dear all,
I am trying to do an application which its role is to disable a boolean control after a specific date.
This specific date is chosen by the user in a string control.
For ex. the user enter the date 01.01.2015, and the application should disable the boolean control 1 year after so at 01.01.2016 (to do so, the application should always running ...)
Could you please suggest me an easy way to do that?
Of course I know that I can exract the day,month,year of my string and then convert then to numbers. But its quite difficult. I am searching for an easy way ! 🙂
Thank you very much
(3,042 Views)
Hi joobin,
some simple pseudocode:
IF timestamp1 >= timestamp2 THEN
  disable(boolean control)
ENDIF
What's the problem in comparing two timestamps?
Why do you use a string control at all? Why not use a timestamp control, formatted to only show the date?
(3,036 Views)
Ah yes!!
In fact I did not know that we can use Timemap control.
Of cours it will be much easier to use that.
That is all I needed !
Thank you very much.
(3,027 Views)
