datasockets server
I'm using a DataSockets Server to run a stepper motor (connected to a PCI 6024 NI Card) with a simple program. It was working the first time I launched DataSockets Server until I shutdown It. But know, when I'll restart the DataSockets Server It doesn't work anymore and I don't know why. I tried with several Computer and each time it's the same thing : The program is Running the first time and not after ... Can you Help me ?
(2,698 Views)
Hello M67,
Thanks for posting on National Instruments forum.
Can you give us more information about your application? Which version of software are you using? Can you send a example?
If you restart your computer, can you run your application one time?
Kind regards
Flo
(2,677 Views)
I'm using Labview 8.5 and see attached a print screen of the error.
In fact, I have 2 computer, one connected to the PCI 6024 E NI card which the Stepper motor is pluging and the other computer to send the data to the first one via datasockets server.
(2,672 Views)
