datasocket read with unpublished variable
When I try to read an unpublished variable using datasocket read (dstp protocol), I don't get any errors. Status and Quality fields are also blank. For strings, I can check if the return value is empty or not, but I'm afraid it will not work for a numeric data type.
Is there any way to check if a variable exists or not?
(2,755 Views)
hi abdel,
There are a few things here.  First, I found this KnowledgeBase discussing behavior of DataSockets when opening a connection.
How Do I Set an Initial Value for a DataSocket/OPC Connection in LabVIEW?
Second, I would suggest simply trying it.  Try polling the unpublished value and see what value is returned.
Stephen Meserve
(2,726 Views)
