datasocket/OPC server error?
I meet communication problems with LabView 7.1 on a production line:
I have 2 PC with 2 different LabView programs and they have to exchange data (Ethernet LAN).
The systems exchange differents VARIABLES, using different protocols : mainly dstp (with data socket server) & opc (with OPCLabView server). For these 2 protocols, I use "data sockets write/read" functions in the code.
Most of the time, the communication works correctly.
But approx. 1*/month, problems occur : some of the VARIABLES stop to be uptdated. Others VARIABLES continue to exchange datas correctly!!
I'm new in the company, so i have never seen the problem by myself, but a colleague said me he saw (thanks to "Server Explorer") that the NI OPCLabview was working wrong.
I want to resolve these problems, but I don't know what's the real root cause of the problem :
- is it the OPC Labview server  (v. 7.1) wich has internal bugs?
- Or is it the datasocket Write functions (v. 7.1) which has internal bugs?
- Others hypothesis?
Actually, most of the critical VARIABLES communicates via dstp, that's why I don't think that the NI OPCLAbVIew server is the cause.
What'is your opinion ? Maybe is it a OS Windows problem?
Have you ever met this kind of problems?
Do you advise me to upgrade to the last LabView version?
Many thanks for your help
Benoît Jouret
Automation engineer
(2,741 Views)
Do you get any error message? Can you post your vi?
(2,725 Views)
I don't get any error message!
Actually it will be very difficult to post my vis because the 2 programs are huge, with a lot of subvis.
It has been coded more than 5 years ago by a chemistry engineer, so you will take a lot of time to understand the code 😉
I'm now trying to resolve the problem with NI because it seems to be a referenced bug.
Many thanks.
Benoît Jouret
Automation engineer
(2,710 Views)
