database
I have a proyect made in labview 6 working in real time. The input data comes from a table in access 97. My problem is to know what is the best way to optimize this whitout the tables brokes. By the way, the data are taken a the rate 4 samples per second,
in a 1 hour session.
Thanks, if any user speak spanish, better.
MFS.
(2,754 Views)
What do you mean by optimizing without breaking the tables? Also, what method are you using to connect to Access 97, and what are you trying to optomize? (speed? memory usage?) If you give us a little more information, maybe we can suggest a few things.
(2,754 Views)
