database wild card
I am having trouble using wildcard matching in database toolkit queries.  When working directly in Microsoft Access a query using the expression Like "File*" returns the expected data but  when sent through the tool kit results in an error complaining about illegals characters.
Error -2147217904 occurred at Conn Execute.vi->DB Tools Select Data.vi->SQL_like.vi
Possible reason(s):
.  Invalid string: specified field does not exist or contains an unsupported character
If I replace "File*" with 'File*' then no no error occurs but no results are returned because, presumably, the * is no longer treated as a wildcard.
(3,909 Views)
Try using a % for the wildcard.
Jim
(3,898 Views)
% inside single quotes works.  Any other wildcard characters work inside single quotes?  Is this documented anyplace?  Thanks.
(3,887 Views)
Actually, the % is the SQL standard wildcard for use in LIKE clauses. I'm surprised that something else worked at all...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,885 Views)
Hi Ken, does using two ticks('') instead of the double quotes (") work in getting the wildcard to go through?
Joshua B.
(3,849 Views)
Using double ticks producing a slightly different error message:
Error -2147217900 occurred at Conn Execute.vi->DB Tools Select Data.vi->SQL_like.vi
Possible reason(s):
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Microsoft Access Driver] Syntax error (missing operator) in query expression 'item Like ''C*'''. in Conn Execute.vi->DB Tools Select Data.vi->SQL_like.vi
The outermost ticks were added by the error processing.  The double inner ticks ''C*'' are mine.
(3,834 Views)
