database udl
I have created a vi for accessing a udl file and put the data from the file to a table in front panel. but unfortunately when i run it its giving an error.
Error:
NI_Database_API.lvlib:DB Tools Open Connec (String).vi->NI_Database_API.lvlib:DB Tools Open Connec (Path).vi->TutorialGenerateDisplay 1.vi<ERR>ADO Error: 0x800300FB
Exception occured in Microsoft OLE DB Service Components: The file is not a valid compound file. in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->NI_Database_API.lvlib:DB Tools Open Connec (Path).vi->TutorialGenerateDisplay 1.vi"
I have attached the block diagram..Is that the right way to acess database.
Thanking you,
Sushmith
(4,439 Views)
Check the database connection and the UDL file.
Rajesh Raghavan Nair
Certified LabVIEW Architect
Certified Teststand Architect
(4,428 Views)
May i know what is wrong with the connection..??
Thanking you,
Sushmith
(4,426 Views)
(4,393 Views)
