database toolkit install
Database toolkit install problem – multi versions
I have 2 versions of LV installed on a W7 box. The Database Connectivity Toolkit runs fine for the 2009 version. The 8.6 version has broken VIs. Error message - expired or invalid licence.
The tool was not installed properly but every time I try to install it the installer tries to overwrite the 2009 version instead of the 8.6 version. When I do a custom install and try and set the correct location, the installer overwrites the location I set and adds a  LV2009 directory.
How can I install it to the correct version of LV?
(2,526 Views)
By taking the same version of the Toolkit as the version of LabVIEW is where you want to install it.
Christian
(2,506 Views)
