database modify element in row
Hi all,
I have a question about the database toolkit.  How do I query a particular row in a table and modify an element in that row?  By doing this, the database table is getting updated.
Yik
(2,728 Views)
Accepted by topic author jyang72211
You use the Execute Query and do an UPDATE
UPDATE table_name
SET column1=value, column2=value2,...
WHERE some_column=some_value
(2,716 Views)
When I write sql query, I always use it to get data, and I have never tried to update a table in a database.  I didn't know that you can use the querying function to update a table.  Thanks, it worked.
Yik
(2,694 Views)
