database access specific bug
Using database access components in Labview 8.2 to access a MS access database.
If a column is called "Language"  it cant be read or used.
Any attempt to read the column, or data within the column using sql or any other method will fail.
If the column is renamed, it will work.
Why is it so,.
Why is the column name "Language" specifically  singled out to not work in Labview database access vis.
(2,642 Views)
'Language' is a reserved word in SQL. The Access help lists these words and using any of them will cause the same problem.
(2,625 Views)
