data transfer using ethernet between 2 pcs
hi
i need to know that is there a way in labview to use ethernet (LAN cable) to tranfer data between 2 pcs meaning that i want to send data from one pc to another pc using ethernet ? or any example in labview ?
Regards
Message 1 of 9
(4,340 Views)
Hi nolsqn,
use the example finder. Smiley Wink Search for TCP or TCP/IP. You will find lots of examples.
Mike
Message 2 of 9
(4,333 Views)
And if you are directly connecting the two pc's, be sure to use a cross-over cable.
Message 3 of 9
(4,308 Views)
to dennis knight.
I am trying  to send data between 2 pcs using ethernet . the examples  of tcp/ip in labview when i run them gives an error "network unreachable or reset".
Regards
Message 4 of 9
(4,270 Views)
Is the other pc reachable? Have you tried to ping it?
Message 5 of 9
(4,248 Views)
I must admit I am a begginer with LabView and I would need some hel with this:
what about data transfer using wireless?  I found no related examples in LabView examples.
Thanks a lot and have a good day!!
Ana.
Message 6 of 9
(3,910 Views)
Hello Ana,
The TCP/IP comunication does not depend on if you have a wired or wireless connection.
The first thing you must know is that your PC's should have a network path between them.
Configure your internet connections on both PC's in order to assure that.
You can use the operating system ping command to check this.
If your both PC's are only connected to each other and not to some externeal networks like the Internet, you should also disable firewalls just to avoid having another variable to think about - afterwards you can even define some exceptions to your firewall setting to allow this communication.
After this, the TCP/IP examples should work.
Hope this helps,
Paulo
Message 7 of 9
(3,903 Views)
People are actually trying to help here. See attached picture.
 Here is some useful tips for the Labview beginner (we have all been there some time)
1)Then starting a new Labview session enable context help (Ctrl+h). Do not be afraid to use the detailed help option
2)Then stuck, go to help in the toolbar then select find examples
Message Edited by Coq rouge on 04-28-2009 12:32 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 8 of 9
(3,899 Views)
Thank you both a lot!! :smileyvery-happy:
These are very helpful.. and I am very grateful!!
 Have a nice day!
Ana.
Message 9 of 9
(3,884 Views)
