data stopping at case structure
When the block diagram operates, the only data saved to the spreadsheet file are sets of 0.00000.  I assume this means that my data is not getting into the case structure, and that the array is adding data of 0 each iteration.  What problems am I having with data-flow? Here is the attached file, the structure I am inquiring about is on the right side.
(2,435 Views)
Are you sure you are getting any data out of your scope functions?
Try putting probes on all the wires that make up your data and see what they are showing while your VI is executing.
(2,420 Views)
