data seperation
i have attach here doc. file with my problem
Message 1 of 14
(3,789 Views)
Hi kalu,
do the NI AEs don't get in-house lessons on LabVIEW? Don't you have possibilities to talk to LabVIEW AEs in-house?
Why do you attach proprietary file formats (twice) instead of plain text?
In your example text there's a semicolon instead of a colon, that might interrupt your matching routine...
Message 2 of 14
(3,786 Views)
thanks for reply and so sorry that i have attached two times a same file.
in given example there are : and ; but data after : are only important . i donnot know how to get the poper solution.
thanking you
kalu
Message 3 of 14
(3,778 Views)
Try the "Search/Split String" VI. This will search the string and split it at the ":" character.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
Message 4 of 14
(3,760 Views)
if i use  search/split string then i can only seperate from first line but there are around 100 line of data how can i seperate data after :  in each line . i have to take data from each line .
thanking you
Message 5 of 14
(3,756 Views)
Hi kalu,
using SpreadsheetStringToArray you could transform your text into an array of strings, one line to one string. Then in a loop you could examine each string.
Or you use PickLine to pick each line...
Message 6 of 14
(3,741 Views)
@Gerd: Blue name plate != NI employee (at least not necessarily).
Showed this somewhere in this thread.
Norbert
Norbert
Expert: Geometry
Message 7 of 14
(3,734 Views)
Hi Norbert,
so NI once choose to have blue name plates for it's AEs, but fails to force Lithium to apply a correct filter for the email addresses?
Well, learned something new for today 🙂 (Apart from controlling a stepper motor using CANopen on cRIO+NI9853...)
Message 8 of 14
(3,727 Views)
Gerd,
well, not only for AE's but also for all other employees. E.g.Brittany Wilson, the NI Content Specialist.
A day without learning anything is a sad day....
Norbert
Norbert
Expert: Geometry
Message 9 of 14
(3,721 Views)
thanks for reply but what should i have to give in formate string shoud i write : or ???
Message 10 of 14
(3,716 Views)
