data saving
Hello everyone,
Is it possible to use several File I/O.vi (Excel format) in one Case structure (consisted of 3 or 4 cases and every case one data saving vi)?
Thanks in advance....
(3,765 Views)
Why not?
You can open some files and store references.
Or you can work with one reference but write into file different data
(3,760 Views)
You said File I/O in excel format.. I can't get in tho:(
if you are using open file, you keep refnum and utilize when reading or writing function comes.
if you are using Write/Read Delimited Spreadsheet.vi, you can easily get array data from vi so no problem using in case structure.
(3,712 Views)
Hi Mr. Jaylee,
I have attached two picture here. one is "water level measurement" another "ion level measurement". 2 separate "Write Meas file" has been used. the "ion level measurement" works good but didn't get any data in "water level measurement" file. Bother were "xlsx" format.
(3,693 Views)
Accepted by topic author Chowdhury_Milon
In water level measurement you use "AND" function, and save to file  ONE element, not array (signal)
(3,681 Views)
