data import
this is abhishk mudgal and i am new to labview. i am working on processing of biomedical signals using labview. for the same i downloaded some signals from a website named physionet.org in .txt format but i am not able to import them to labview. i tried to change them in .xml format and then try but still it didn't worked. i am using labview 8.2 version. i m attaching a data signal for the same purpose of .txt format.
please help me out.
(3,717 Views)
you can use Read from spreadsheet file.vi and put your datas into a 2D-array.
18115iBEB07F0B41F2E8D2
You can open txt or xml files with this.
Also, be careful about decimal operator : look into your OS parameter (in windows it is in the regional parameters) to see if it is set to . or ,
Hope this helps,
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
(3,716 Views)
Hi JDLabview
I already tried this thing but its not working out. When i tried read from spreadsheet and given path of the file as input file and connected its output to a table or graph or chart it didn't showed any output.
thanks for the reply and please help if you can find out the solution.
(3,682 Views)
Hi abhishek,
well, your file is an example of a bad file format. Even the included header is wrong: it says "hh:mm:ss.mmm" for the time column, but the values are given as "m:ss.mmm"...
So you should:
- load the file as string
- convert the string using SpreadsheetStringToArray into a 2D-array of strings
- get rid of the header using ArraySubset
- convert the first column into timestamps
- convert the 2nd column into DBLs
(3,677 Views)
Please visit our Biomedical User Group at www.ni.com/biomedical
You can find information about our Biomedical Starter Kit (free download) which includes file import utiliities, as well as signal processing VI's for biomedical signals.
Steve
(3,648 Views)
