data exchange between mein vi and sub vi during execution of sub vi (sub vi should get some data from main vi instantly)
To control a test bench I have one main vi with all the controls, displays, and everything needed to control the test bench.
I am aware of the advantages of sub vis (nr 1 advantage is the possibility to use the sub vi several times at different locations) but in this test bench program I abstained from subvis, because on my front panel I have some controls that have to apply instantly, e.g. a Stop-button.
I couldn't get around one subvi: I have to move some axles, so I created a sub vi called "move axle".
Now my problem is, if the user presses the stop-button on the main front pannel, the axle movement should stop instantly, but due to the sub vi, it does not stop until the sub vi is finished.
Another similar problem is, during the sub vi execution the front panel is frozen (all displays and charts stop).
How can I get around this problem? Is it possible to exchange some data between main vi and sub vi during sub vi execution?
LabVIEW 7.1 (I used to program with C and Labview 6)
Win XP
Johannes
Message Edited by johanneshoer on 02-27-2009 04:49 AM
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(4,440 Views)
Hi Johannes,
you should read about using references, queues, globals Smiley Wink
(4,417 Views)
Gerd,
thank you very much. I searched a little as well and I found this:
"Data transfering from sub-vi to main-vi "
http://forums.ni.com/ni/board/message?board.id=170&message.id=47364&query.id=3803#M47364
 which seems to be the solution.
Greetings
Johannes
Greetings Johannes
(4,414 Views)
