data broadcast through firewire
we would like to have a computer broadcast data (2d arrays of SGL) to several other computers at a rate of 20mbyte/s. tcp/ip turns out to be too slow and udp isn't reliable enough, which our application cannot torrelate. all our computers have at least one firewire port. we wonder is there a way to do real-time data broadcast using firewire, maybe through some kind of a firewire amplifier? if not, can we at least transfer data using firewire between two computers? where can we find any example vi's on this? thanks!
(2,820 Views)
Assuming you are using windows ?
You could always enable the TCP/IP Protocol on the FireWire network.
Maybe the FireWire hardware is faster then the ethernet's.
Don't know if this keeps up the speed but it's worth a try.
Tom
(2,810 Views)
