data acquisition with different sampling rates
I have a few questions about use of the OMB-DAQ-3005 with different sampling rates.
For our application we have 8 analog inputs. Two of which are fast response and will need to be sampled often.  We have a quadrature encoder (1000 CPR operating at 1800 RPM).  We plan to sample encoder X4.  For the fast response analog inputs, we desire to trigger a sample every pulse or every few pulses, thus creating a timestamp with the encoder position in relation to index position as well as the two fast analog inputs.  We must have data correlating the analog inputs with the encoder position.   The other analog inputs, we want to measure relatively slowly (e.g. once every 5 sec or similar).
How do I go about setting up two (or more) different sampling rates in which I can sample inputs at different frequencies?  Also, is there a way to reset encoder count upon index trigger such that I will have encoder position with respect to index?
Message 1 of 10
(5,505 Views)
Accepted by topic author minachibi
Maybe you'll find somebody here that uses the OMB-DAQ-3005, but this forum is really more intended for LabVIEW programming questions.
I've never used the OMB-DAQ-3005, but out of curiosity I took a peek at the OMB-DAQ-3005 user manual.  The answer to your two questions are:
1.  You can't run a multiplexed DAQ device (like this one) at independent rates per channel.
2.  The OMB-DAQ-3005 supports a Z Index feature to reset the counter--look for documentation on how to configure it in whatever software interface you are using.  If you're stuck you might want to seek out the appropriate support channel for this particular instrument.
Best Regards,
John Passiak
Message 2 of 10
(5,467 Views)
Thank you for your answer.
Can we use LabView with this device.
Thanks again
Message 3 of 10
(5,455 Views)
Search Omega's website or google to see if they have LabVIEW drivers.  It appears that they do here.  ftp://ftp.omega.com/public/DASGroup/products/OMB-DAQ-3000/
Message 4 of 10
(5,438 Views)
Message 5 of 10
(5,416 Views)
If it's as slow as 5 seconds, you can simply make single reads in the program instead of setting a sample rate. If you have a timed loop or timeout case check if enough time has passed.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 10
(5,404 Views)
I also have a omega omb daq 3005 that I want to use with labview
I downloaded the software/driver in that link but labview doesn't recognize my device
When I plug the usb port, my computer recognizes the device, but in LabView it doesn't and when I use tools > measurement & automation explorer my device doesn't appear on the list...
Any suggestions ?
Thank you,
Ana Carolina
Message 7 of 10
(5,202 Views)
Measurement and Automation Explorer is only going to show NI devices, which the Omega is not.
Have you tried using the LabVIEW drivers that are in the link?
Message 8 of 10
(5,195 Views)
Yes. I installed the labviewdaqcom2setup.exe.
It creates a support folder that contains a configuration utility and  DaqIPConf
but when I open them, I get  "no devices found"
so if Measurement and Automation Explorer only shows NI devices, I can`t use the DAQ assist at measurement i/o function palette, right?
Does labview has another assistent to make it easier to get a continuos thermocouple reading from not NI`s devices?
Message 9 of 10
(5,176 Views)
If the omega utility does not recognize omega hardware, you need to contact omega.
No, there is only the DAQ Assistant. Ask omega for an example program, assuming you can get windows to recognize it.
Message 10 of 10
(5,173 Views)
