data acquisition problem
Hi gang -
I am attempting to create a program to provide online feedback to my
subjects. The feedback should be of a predetermined length (5 sec) and
in real time. I modified the Continuous Acquisition and Chart example
to display my data in real time by manipulating the dx value of the
chart and counting the number of iterations of the loop to determine
when the acquisition should be stopped. It worked when only sampling
one channel, but I have added 3 more as well as having added a second
(similar) chart. I realize this changes the sampling rate and have
accounted for that, but the acquisition is no longer 5 secs long (it is
much longer). I've been changing the dx value and nothing seems to
work. There has to be a better w
ay to do this. Any suggestions?
Jamie Johnston
(2,657 Views)
Hi Jamie
If you change the sampling rate, but not the number of scans to read, then
the length of the aquisition will change - have you changed the number of
scans to read (per channel)?
Paul Davey
Jamie Johnston wrote:
> Hi gang -
> work. There has to be a better way to do this. Any suggestions?
> Jamie Johnston
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton Park, Western Australia, Australia. 6008
email: P.C.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of the Lord will be saved." Romans 10:12
"For all have sinned and fall short of the glory of God, and are justified
freely by his grace through the redemption that came by Christ Jesus."
Romans 3:23-4
(2,657 Views)
