daqmx timing source issue
I have attached zip containing 2 folders. Both are doing same functionality but one using software timed 50ms loop. the other one is hardware based timing source.
I run , quit & re-run the application. Both the applications works well. But the ISSUE folder containg application hardware timing sourced app, after quit, the EXE process keeps running in the background & needs to be stopped using Ctrl+Alt+Del invoking the task manager.
As many times I click on to run the app, it works ok only, but holding the EXE process in background.
Hope someone helps to resolve this. Im using LV2009 + PCI 6229.
Kousy
Message 1 of 1
(2,224 Views)
