daqmx split or filter signal
Goodday,
On a PC 4461 card, there are 2 mic's connected. I use the Read.Vi from the DAQmx for this with "ai0:1" as physical adresses.
These signals are use to calculate the rms value.
And this value is send to
Ai0 => Ao0
and
Ai1 => Ao1
However sometimes i want to use only one mic, and thus only for example use "ai1" however when i do this the signal from Ai1 goes to Ao0.
Ai1 => Ao0.
It seems that the Read.vi write every channel to "waveform channel 0" instead of "Ai1 to waveform channel 1"
How can this be changed or filtered?
And is there a way to create a pulldown control to selelect Ai0:1 (multiple channels)? the one is create now is only for one channel selection.
(3,182 Views)
Added a picture for example
(3,171 Views)
Accepted by topic author Paul82
The channel select control/constant does have a pulldown for selecting one or more channels. Just use the Browse option.
If you only have one channel selected, you only have a single element in the waveform array so if you always want ai1 to be displayed on a specific graph, put the index array function inside of a case statement. You would have three different cases - ai0 only, ai1 only, ai0 and ai1. Wire out the case statement to the graphs.
(3,166 Views)
