daqmx clear error
Smiley Tongue
hi
i installing my exe aplication on pc
i try to execute the exe file and recieve
daqmx clear tes.vi   not found error 21
i have succed to activate my exe file on other computers is there other things i can do i havent found the vi
in other places
(2,813 Views)
When deploying an application make sure that the LabVIEW run-time engine and the device drivers are installed on the target computer.  Since you have built an installer for your application, the run-time engine should install automatically, however the DAQ drivers will not.  Try installing the same version of the DAQ drivers on your target as are installed on the development computer.
Andy F.
(2,800 Views)
