daqmx channel property node
Hi all,
I've downloaded an example for a quad counter which uses a daqmx channel property node to specify A,B,Z channels.
I have tried to replicate the example using LV8.1 but the only properties that I get are 'Active Channel' and 'General Properties' with 4 sub properties. Why don't the channel properties show up? What am I missing here?
I have attached a jpeg of what im talking about. Any help is appreciated.
Cheers,
Dave
(2,841 Views)
Hi David,
This happens when you have not inserted a DAQ device in your system or your DAQ device is not detected by your MAX.
You could do one of the following
1. Insert a DAQ card into the PCI/PXI slot
or
2. Simulate a DAQmx device in MAX.
By doing this, the corresponding DAQmx properties will show up
(2,834 Views)
Too easy. Thanks!
(2,830 Views)
