daq channel name constant
I'm using LABVIEW 6.1 on a computer that does not have a DAQ card
installed.  I would like to create a listbox that allows selection of
multiple DAQ channels.  My problem is that the AI Group Config.vi
requires a DAQ Channel IO data type which is neither a string nor an
Integer.  I tried to use the DAQ channel name constant, however I
wasn't able to enter a value for the constant. This problem may be
caused by the DAQ card not being installed.
Therefore, my question is that if I had the DAQ card installed, would
the DAQ Channel Name Constant allow me to enter a value?
Steve
(2,648 Views)
I believe you can at least type a name into the control/constant if you right click on it and select "Allow Undefined Names". Then just double click in the control and start typing.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,636 Views)
Thanks Ed,
That works!
(2,633 Views)
