daq assistant properites won't open
We are using version 8.0.1 LV with daqmx version 8.7.1. Win Xp with a PCI-6025E card, SCB-100 is attached. I can measure the thermistor in the SCB-100 in Measurement and Automation so the hardware seems to work OK. The problem is using Daqmx in LV. I'm following the tutorial at http://zone.ni.com/devzone/cda/tut/p/id/2744 . When I drop the Daq Assistant onto the Block diagram it does not open the properties page to allow me to configure an analog input, double click won't work, single click and selecting properties does nothing. In Measurement and Automation I can create a task and it does launch the daq-mx box and setup measuring with the PCI-6025E. Probably a simple setting issue somewhere, any ideas ?
(4,461 Views)
Accepted by topic author sstewart
See this discussion and this one.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,448 Views)
Thanks, those links helped. Basically going to windows control panel, mod/del National Instruments, delete Daqmx, reboot, re-install daqmx and it works. I think there were other versions mixed in with 8.7.1.
(4,421 Views)
