daq assistant hang
Hi-
I am running LabVIEW 2013 SP1f1, DAQmx 9.8 and NI Max 5.6 on a Win 7 32bit install and can not add the DAQ Assistant Express VI to the block diagram.  So far I have:
- Repaired DAQmx
- Upgraded from 2013 to 2013 SP1
- Deleted DAQmx and reinstalled twice
- Deleted and reinstalled the drivers
- Updated to f1
I am completely stuck here...  any advice?  When I try to place an instance of DAQ Assistant LabVIEW hangs and becomes unrespoinsve requiring force quitting via the task manager.
Any help is greatly appreciated!
(2,721 Views)
Can you try reinstalling your LabVIEW installation first, and then the DAQmx driver?
Thomas N.
(2,677 Views)
