daq assistant calibration drift
Helloo,
I am using the USB 6229 DAQ. In my VI I am using the DAQ assistant to calibrate my device before I begin recording. However I am finding that there is a constant drift in the 'uncalibrated value' before I commit the new values that I want to use.
Is this drift normal or is there a problem with my DAQ?
any help would be appreciated,
Al
(2,623 Views)
How much drift are you measuring?  Generally NI devices seem to be quite stable.  Are you allowing sufficient warm up time?
Lynn
(2,616 Views)
The uncalibrated figure is approximately '0.4523' and it constantly reduces in size. If i leave it for 5 mins it will be around 0.3800. It doesn't seem like a majoy drift but the uncalibrated max and min points of my device are around 0.2 and 0.6.
The DAQ had been on for about 7 hours and i was detecting a drift so I restared everything and tried again numberous times over 2hrs and i detected the same drift in calibration.
any ideas?
Al
(2,611 Views)
What is connected to the input while this drift is occurring? What is the input configuration, differential or single ended?  What is the full scale range?
Lynn
(2,607 Views)
