daq 9219 problem
respected sir we are working on our final year bachelors project. we are using DAQ-9219 for  the stress analysis using load cells.and the 9219 is not working.the excitation voltage of load cell is 9 to 12 volts and that of DAQ is upto 2.7 volts. please share your expert opinion with us
(2,249 Views)
Hi Zee,
as can be read in the datasheet of the NI9219:
Excitation level is a characteristic and is not software-selectable.
So you cannot control the excitation voltage using any software and need to work with the voltage you get.
I guess the datasheet of that load cell is saying something like "typical excitation voltage", but you can also operate that load cell with less excitation…
You should be able to read datasheets in your final bachelor year…
(2,243 Views)
